Ir para o conteúdo principal
Shimano Zee Gearshift group cable replacement
O que você precisa
  1. Shimano Zee Gearshift group cable replacement, Gear cable: passo 1, imagem 1 %32 Shimano Zee Gearshift group cable replacement, Gear cable: passo 1, imagem 2 %32
    • First we shift to the smallest sprocket, otherwise the gear cable in the shift lever is wrapped around a "pulley" and cannot be pulled out later. Then the screw that covers the opening for the shift cable on the shift lever (trigger) is loosened. For this we use a Phillips bit from the Macro Bit Set.
  2. Shimano Zee Gearshift group cable replacement: passo 2, imagem 1 %32
    • In the second step, we loosen the screw that clamps the shift cable in the rear derailleur. The cable should now be loose and without tension.
  3. Shimano Zee Gearshift group cable replacement: passo 3, imagem 1 %32 Shimano Zee Gearshift group cable replacement: passo 3, imagem 2 %32
    • Next, we pull the black outer casing out of the shift lever (trigger) and push the shift cable through the opening screwed on in the first step.
  4. Shimano Zee Gearshift group cable replacement: passo 4, imagem 1 %32 Shimano Zee Gearshift group cable replacement: passo 4, imagem 2 %32
    • Now the gear cable can be completely pulled out of the outer casing and removed.
  5. Shimano Zee Gearshift group cable replacement: passo 5, imagem 1 %32
    • Now the shift cable is pushed through the opening in the shift lever (trigger) and threaded through. Finally, the cover screw that closes the opening is screwed back on. This makes assembly easier, as the shift cable can no longer slip out of the shift lever.
  6. Shimano Zee Gearshift group cable replacement: passo 6, imagem 1 %32
    • Now we can thread the shifter cable back through its outer casing. Note: make sure that the end caps sit on the outer shell! These tend to fall off during disassembly and are forgotten.
  7. Shimano Zee Gearshift group cable replacement: passo 7, imagem 1 %32
    • After threading the shifter cable back through its outer casing, we place the shifter cable under the plate of the clamping screw on the rear derailleur. In this step, the clamping screw is not yet tightened, since we are still taking care of the basic setting of the rear derailleur.
    • Then tighten the screw with the torque wrench and 6 Nm.
Linha de Chegada
Um agradecimento especial a esses tradutores:
de en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Dennis
Membro desde: 07/27/15
372 Reputação
Autoria de 1 guia
Equipe
iFixit Membro de iFixit
Staff
119 Membros
Autoria de 19.522 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 21
Últimos 30 dias: 54
Ao todo: 1,202
