Ir para o conteúdo principal
Sharper Image SVC430 Tripod Nut Replacement
O que você precisa
  1. Sharper Image SVC430 Tripod Nut Replacement, Sharper Image SVC430 Disassembly: passo 1, imagem 1 %32 Sharper Image SVC430 Tripod Nut Replacement, Sharper Image SVC430 Disassembly: passo 1, imagem 2 %32
    • Power off your device before you begin.
    • Use your thumb to push down on the lever that says "open" while simultaneously pushing up the latch with your other thumb.
  2. Sharper Image SVC430 Tripod Nut Replacement: passo 2, imagem 1 %32 Sharper Image SVC430 Tripod Nut Replacement: passo 2, imagem 2 %32
    • Once the latch is free, simply pull the front of the waterproof case off and slide the camera out.
  3. Sharper Image SVC430 Tripod Nut Replacement: passo 3, imagem 1 %32 Sharper Image SVC430 Tripod Nut Replacement: passo 3, imagem 2 %32 Sharper Image SVC430 Tripod Nut Replacement: passo 3, imagem 3 %32
    • Locate the bottom of the device.
    • Now, using the metal screwdriver, unscrew the screw on the bottom of the device.
  4. Sharper Image SVC430 Tripod Nut Replacement: passo 4, imagem 1 %32 Sharper Image SVC430 Tripod Nut Replacement: passo 4, imagem 2 %32
    • This panel should come off easily, do not apply too much pressure.
    • Use the plastic opening tool to pry open the plastic panel from the top of the camera.
    • Locate the two screws on the top of the device.
  5. Sharper Image SVC430 Tripod Nut Replacement: passo 5, imagem 1 %32
    • Use the JIS J0 screwdriver to unscrew the two screws on the top of the device.
  6. Sharper Image SVC430 Tripod Nut Replacement: passo 6, imagem 1 %32 Sharper Image SVC430 Tripod Nut Replacement: passo 6, imagem 2 %32 Sharper Image SVC430 Tripod Nut Replacement: passo 6, imagem 3 %32
    • Use the plastic opening tool to pry off the back panel.
    • The back panel will come off easily.
  7. Sharper Image SVC430 Tripod Nut Replacement: passo 7, imagem 1 %32
    • Use the metal screwdriver to unscrew the screw from the back of the device.
  8. Sharper Image SVC430 Tripod Nut Replacement: passo 8, imagem 1 %32
    • Use the plastic opening tool to pry off the front panel of the device.
  9. Sharper Image SVC430 Tripod Nut Replacement: passo 9, imagem 1 %32
    • Using the screwdriver, unscrew the screw located underneath the front panel.
  10. Sharper Image SVC430 Tripod Nut Replacement: passo 10, imagem 1 %32
    • Be gentle with the device since there are wires attached to the front plate and two halves.
    • Gently pull both sides of the device to expose the interior of the device.
  11. Sharper Image SVC430 Tripod Nut Replacement, Tripod Nut: passo 11, imagem 1 %32
    • Locate the two screws that attach the tripod nut to the device.
  12. Sharper Image SVC430 Tripod Nut Replacement: passo 12, imagem 1 %32 Sharper Image SVC430 Tripod Nut Replacement: passo 12, imagem 2 %32
    • Unscrew the two screws located on the back of the half that the tripod nut is located.
    • Once the screws are removed, the tripod nut can easily be removed.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 231
