Introdução
The user will learn how to:
- Remove the device from the case
- Completely tear down the device
- Remove the lens
O que você precisa
Use your thumb to push down on the lever that says "open" while simultaneously pushing up the latch with your other thumb.
Behind the lens, use the metal screwdriver to unscrew the two screws holding the lens in place on the circuit board.
Uma outra pessoa concluiu este guia.
