Introdução
Removing the back panel is a prerequisite to any replacement or repair you need to do. When the back panel is removed the electronics and the speaker are visible and available to be removed or repaired.
O que você precisa
Use a #0 Phillips screwdriver to remove the eight 13mm Phillips head screws from the back panel.
Quase terminado!
Conclusão
