Ir para o conteúdo principal
Sharp-EL-531xg Battery Replacement
O que você precisa
  1. Sharp-EL-531xg Battery Replacement, Battery: passo 1, imagem 1 %32
    • Press the 2nd F button and then the OFF button to power down the calculator.
  2. Sharp-EL-531xg Battery Replacement: passo 2, imagem 1 %32 Sharp-EL-531xg Battery Replacement: passo 2, imagem 2 %32
    • Flip the calculator over so the back is facing upwards.
    • Remove the single screw from the battery panel using a Phillips #0 screwdriver.
  3. Sharp-EL-531xg Battery Replacement: passo 3, imagem 1 %32
    • Remove the battery cover using two fingers.
  4. Sharp-EL-531xg Battery Replacement: passo 4, imagem 1 %32 Sharp-EL-531xg Battery Replacement: passo 4, imagem 2 %32 Sharp-EL-531xg Battery Replacement: passo 4, imagem 3 %32
    • Place a spudger in the slot next to the battery and pry upwards to remove the battery.
    • Avoid using a sharp tool to remove the battery.
  5. Sharp-EL-531xg Battery Replacement: passo 5, imagem 1 %32
    • Place the new battery into the slot with the positive (+) side facing upwards
    • Don't press the battery too hard.
  6. Sharp-EL-531xg Battery Replacement: passo 6, imagem 1 %32
    • Put the battery cover back on.
    • Tighten the battery cover screw with a Phillips #0 screwdriver.
  7. Sharp-EL-531xg Battery Replacement: passo 7, imagem 1 %32 Sharp-EL-531xg Battery Replacement: passo 7, imagem 2 %32
    • Press the On button to turn on the calculator.
    • Flip the calculator over so the bottom is facing upwards.
    • Press the reset button with the pointed end of a spudger to restart the calculator.
Linha de Chegada
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 46
Duração total: 516
