Ir para o conteúdo principal
Sharp LC-42D62U T-Con Board Replacement
O que você precisa
  1. Sharp LC-42D62U  T-Con Board Replacement, Remove the SD card cover: passo 1, imagem 1 %32
    • To replace the T-Con board it is not necessary to remove the base.
    • Lay the the TV flat on a padded surface.
  2. Sharp LC-42D62U  T-Con Board Replacement, Detach the rear cover: passo 2, imagem 1 %32
    • Remove 17 screws.
  3. Sharp LC-42D62U  T-Con Board Replacement, Remove the stand fixing angle: passo 3, imagem 1 %32
    • To reassemble all the parts easily, mark with a permanent marker the location of the screws you are removing.
    • 4 screws hold the nd fixing angle.
  4. Sharp LC-42D62U  T-Con Board Replacement, Remove left and right center angles: passo 4, imagem 1 %32
    • 2 screws hold each center angles.
  5. Sharp LC-42D62U  T-Con Board Replacement, Remove the main shield: passo 5, imagem 1 %32
    • 9 screws.
  6. Sharp LC-42D62U  T-Con Board Replacement, Disconnect connectors: passo 6, imagem 1 %32
    • Insert wisdom here.
  7. Sharp LC-42D62U  T-Con Board Replacement, Remove the tray chassis: passo 7, imagem 1 %32
    • 7 screws.
  8. Sharp LC-42D62U  T-Con Board Replacement, Remove the tray fixing angles and the lug angle top: passo 8, imagem 1 %32
    • Remove the 7 screws holding the lug angle top.
    • Then remove only the bottom screws from the tray fixing angles, leaving the top screws attached to the lug angle top.
  9. Sharp LC-42D62U  T-Con Board Replacement, Remove the T-Con board shield: passo 9, imagem 1 %32 Sharp LC-42D62U  T-Con Board Replacement, Remove the T-Con board shield: passo 9, imagem 2 %32
    • 5 screws.
  10. Sharp LC-42D62U  T-Con Board Replacement, Remove the last screw and disconnect the 4 ribbon cables: passo 10, imagem 1 %32
    • To disconnect the ribbon cables, lift the brown tab on the connector.
    • Make sure the ribbons are positioned correctly in the connector when reassembling the new board.
  11. Sharp LC-42D62U  T-Con Board Replacement, Remove the T-Con board: passo 11, imagem 1 %32 Sharp LC-42D62U  T-Con Board Replacement, Remove the T-Con board: passo 11, imagem 2 %32
    • There are two pads glued under the board (see yellow marks in the picture): use a heat gun to soften them and then gently pry them to detach the board from the frame.
    • There are also 4 tabs holding the board: gently pull the board to release it, after the pads are disconnected.
    • Reposition the pads on the chassis before installing the new board.
Conclusão
Uma outra pessoa concluiu este guia.
Emme
Membro desde: 06/15/17
903 Reputação
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 17
Últimos 30 dias: 50
Ao todo: 1,394
