Ir para o conteúdo principal
Sharp EL-520X Loose Circuit Board Wire Fix
O que você precisa
  1. Sharp EL-520X Loose Circuit Board Wire Fix, Sharp EL-520X Loose Circuit Board Wire Fix: passo 1, imagem 1 %32
    • Remove the single screw from the battery door using a Phillips #00 screwdriver.
    • Remove the battery door.
  2. Sharp EL-520X Loose Circuit Board Wire Fix: passo 2, imagem 1 %32 Sharp EL-520X Loose Circuit Board Wire Fix: passo 2, imagem 2 %32
    • Remove two screws inside the battery compartment using a Phillips #00 screwdriver.
    • Remove the four screws in the corners of the calculator using a Phillips #00 screwdriver.
  3. Sharp EL-520X Loose Circuit Board Wire Fix: passo 3, imagem 1 %32
    • Flip the calculator to the front panel and use an opening pick to pry around the sides of the panel to pop it open.
    • Gently lay it open to reveal the circuit board inside.
  4. Sharp EL-520X Loose Circuit Board Wire Fix: passo 4, imagem 1 %32
    • Using a de-soldering braid, remove the old solder on the area where the loose solar cell wire will be fixed to.
    • Be careful not to damage your circuit board with the hot soldering iron. Do not place the soldering iron tip near the circuit board for long periods of time.
    • Use a soldering iron rest, so you don't directly place the hot soldering iron on your working surfaces which may lead to damages.
  5. Sharp EL-520X Loose Circuit Board Wire Fix: passo 5, imagem 1 %32
    • Place the loose solar cell wire on to the de-soldered area of the circuit board and apply new solder on to that area.
  6. Sharp EL-520X Loose Circuit Board Wire Fix: passo 6, imagem 1 %32
    • Carefully place the back panel back on to the calculator.
  7. Sharp EL-520X Loose Circuit Board Wire Fix: passo 7, imagem 1 %32 Sharp EL-520X Loose Circuit Board Wire Fix: passo 7, imagem 2 %32 Sharp EL-520X Loose Circuit Board Wire Fix: passo 7, imagem 3 %32
    • Secure the back panel with the screws you removed in Steps 1 and 2 using a Phillips #00 screwdriver.
Linha de Chegada
Mohamad Mohamad
Membro desde: 01/18/21
436 Reputação
Autoria de 3 guias
Equipe
York University, Team M-6, Allen Summer 2023 Membro de York University, Team M-6, Allen Summer 2023
YORK-ALLEN-SU23SMG6
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 23
Duração total: 187
