Ir para o conteúdo principal
Sharp EL-510RN Calculator Battery Replacement
O que você precisa
  1. Sharp EL-510RN Calculator Battery Replacement, Battery: passo 1, imagem 1 %32 Sharp EL-510RN Calculator Battery Replacement, Battery: passo 1, imagem 2 %32
    • Find a clean workspace free of clutter.
    • Cover the calculator with the gray screen it came with. This will prevent any buttons from being pressed when it's flipped over.
  2. Sharp EL-510RN Calculator Battery Replacement: passo 2, imagem 1 %32 Sharp EL-510RN Calculator Battery Replacement: passo 2, imagem 2 %32 Sharp EL-510RN Calculator Battery Replacement: passo 2, imagem 3 %32
    • Flip the calculator over so the backside is facing up.
    • Use a Phillips #0 screwdriver to remove the screw securing the battery cover.
    • Use a spudger to pry open the battery cover.
  3. Sharp EL-510RN Calculator Battery Replacement: passo 3, imagem 1 %32 Sharp EL-510RN Calculator Battery Replacement: passo 3, imagem 2 %32 Sharp EL-510RN Calculator Battery Replacement: passo 3, imagem 3 %32
    • Use a spudger to pry the battery out of the back of the calculator.
    • Always use an ESD safe tool when working with batteries or delicate components such as the motherboard.
  4. Sharp EL-510RN Calculator Battery Replacement: passo 4, imagem 1 %32 Sharp EL-510RN Calculator Battery Replacement: passo 4, imagem 2 %32 Sharp EL-510RN Calculator Battery Replacement: passo 4, imagem 3 %32
    • Insert the new battery into the socket.
    • Put the panel back on and screw it into place.
  5. Sharp EL-510RN Calculator Battery Replacement: passo 5, imagem 1 %32
    • Congratulations you've now successfully completed a battery replacement on the Sharp EL-510RN!
Conclusão
Harish Kugathasalingam
Membro desde: 10/21/22
121 Reputação
Autoria de 1 guia
Equipe
York University, Team 4-5, Allen Fall 2022 Membro de York University, Team 4-5, Allen Fall 2022
YORK-ALLEN-F22S4G5
Membros da 2
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 18
Duração total: 408
