O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Place the TV face down on a flat smooth surface as to not scratch the screen.
Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
Remove the two back panels by prying them out with your hands.
Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge.
Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
Using your hands, gently lift and remove the back case of the television.
Remove the two speaker cables from the circuit board by pinching the plastic connectors and firmly pulling up.
Remove the two black tape strips (one on each side) securing the power cable to the frame.
The speakers can now be removed.
Uma outra pessoa concluiu este guia.
