Ir para o conteúdo principal
Sharp Aquos Crystal USB Port Replacement
O que você precisa
  1. Sharp Aquos Crystal USB Port Replacement, Back Panel: passo 1, imagem 1 %32 Sharp Aquos Crystal USB Port Replacement, Back Panel: passo 1, imagem 2 %32 Sharp Aquos Crystal USB Port Replacement, Back Panel: passo 1, imagem 3 %32
    • Peel back the back cover of the phone from the access point to remove it. It should come off easily using your hands.
    Pergunte ao FixBot
    Comentar
  2. Sharp Aquos Crystal USB Port Replacement, USB Port: passo 2, imagem 1 %32 Sharp Aquos Crystal USB Port Replacement, USB Port: passo 2, imagem 2 %32
    • Remove seven 3mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 3.5mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 5mm Star #5 screws shown in the picture with a screwdriver.
    Pergunte ao FixBot
    Comentar
  3. Sharp Aquos Crystal USB Port Replacement: passo 3, imagem 1 %32 Sharp Aquos Crystal USB Port Replacement: passo 3, imagem 2 %32
    • Pry open the back panel using a plastic opening tool. Do this around the edges until you are able to lift it off.
    Pergunte ao FixBot
    Comentar
  4. Sharp Aquos Crystal USB Port Replacement: passo 4, imagem 1 %32 Sharp Aquos Crystal USB Port Replacement: passo 4, imagem 2 %32
    • Disconnect the wire by lifting it up with a plastic opening tool.
    Pergunte ao FixBot
    Comentar
  5. Sharp Aquos Crystal USB Port Replacement: passo 5, imagem 1 %32 Sharp Aquos Crystal USB Port Replacement: passo 5, imagem 2 %32 Sharp Aquos Crystal USB Port Replacement: passo 5, imagem 3 %32
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
    Pergunte ao FixBot
    Comentar
  6. Sharp Aquos Crystal USB Port Replacement: passo 6, imagem 1 %32
    • After removing the wires, carefully snap out the usb port with your hands. It is held down by some plastic clips, so some force may be needed.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 40
Ao todo: 2,997
