Introdução
If you cracked your camera lens or if it is not working properly, you can replace it following this guide.
O que você precisa
Peel back the back cover of the phone from the access point to remove it. It should come off easily using your hands.
Remove seven 3mm Star #5 screws shown in the picture with a screwdriver.
Remove two 3.5mm Star #5 screws shown in the picture with a screwdriver.
Remove two 5mm Star #5 screws shown in the picture with a screwdriver.
