Ir para o conteúdo principal
Shark Vertex Pro IZ682H Pre-Motor Filter Replacement
O que você precisa
  1. Shark Vertex Pro IZ682H Pre-Motor Filter Replacement, Battery: passo 1, imagem 1 %32
    • On the bottom of the device handle, you will find a button on the left side. Press and hold this button.
  2. Shark Vertex Pro IZ682H Pre-Motor Filter Replacement: passo 2, imagem 1 %32
    • While holding the button, slide the battery out of the device.
    • If the battery needs replacing, you can find one on the Shark website.
  3. Shark Vertex Pro IZ682H Pre-Motor Filter Replacement, Pre-Motor Filter: passo 3, imagem 1 %32 Shark Vertex Pro IZ682H Pre-Motor Filter Replacement, Pre-Motor Filter: passo 3, imagem 2 %32
    • On the body of the device you will find there is a large grey button on the side of the dust cup.
    • Pressing this button will release the dust cup from the body of the device.
    • Empty the dust cup if the device has already been in use.
  4. Shark Vertex Pro IZ682H Pre-Motor Filter Replacement: passo 4, imagem 1 %32 Shark Vertex Pro IZ682H Pre-Motor Filter Replacement: passo 4, imagem 2 %32
    • Under the dust cup you will find that there is a white pre-motor filter. Remove this filter.
Conclusão
Tyree Brooks
Membro desde: 10/26/22
486 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 3-2, Botvin Fall 2022 Membro de UMass Dartmouth, Team 3-2, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G2
Membros da 2
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 22
Duração total: 339
