Ir para o conteúdo principal
Shark Vertex Pro IZ682H Brush Roller Replacement
  1. Shark Vertex Pro IZ682H Brush Roller Replacement, Brush Roller: passo 1, imagem 1 %32
    • Detach the power nozzle from the vacuum and turn it so the right side is facing you. Pull down the blue tab in the direction of the arrow.
    • The brush roller should now pop out.
    • Putting the brush roller in again does not require pulling the blue tab. It should pop in with no problem.
Conclusão
Tyree Brooks
Membro desde: 10/26/22
495 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 3-2, Botvin Fall 2022 Membro de UMass Dartmouth, Team 3-2, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G2
2 Membros
Autoria de 5 guias
Um comentário
Hey there, where can I find the replacement rollers? I have been looking around and I do not see any that name the product exactly or in listed in compatible. Are they standard size or something like that?
John Melo - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 49
Ao todo: 1,420
