Ir para o conteúdo principal
Shark Vacuum Pet Hair Power Brush Roller Replacement
O que você precisa
  1. Shark Vacuum Pet Hair Power Brush Roller Replacement, About the unit: passo 1, imagem 1 %32 Shark Vacuum Pet Hair Power Brush Roller Replacement, About the unit: passo 1, imagem 2 %32
    • This Shark model brush head consists of 7 parts: a base frame, a gear, a roller brush, two side screws, a plastic round band, and a top frame of the head.
    • Push the grey button on the back panel to open up the brush head.
  2. Shark Vacuum Pet Hair Power Brush Roller Replacement, Disassembly: passo 2, imagem 1 %32 Shark Vacuum Pet Hair Power Brush Roller Replacement, Disassembly: passo 2, imagem 2 %32 Shark Vacuum Pet Hair Power Brush Roller Replacement, Disassembly: passo 2, imagem 3 %32
    • Take the purple gear, belt, and brush out of the body.
    • Save the belt as this is needed to make the unit operate.
  3. Shark Vacuum Pet Hair Power Brush Roller Replacement, Replacing the brush: passo 3, imagem 1 %32 Shark Vacuum Pet Hair Power Brush Roller Replacement, Replacing the brush: passo 3, imagem 2 %32 Shark Vacuum Pet Hair Power Brush Roller Replacement, Replacing the brush: passo 3, imagem 3 %32
    • Pull out the side screws from the right and left side of the old roller brush and put them on the replacement roller brush.
Conclusão
8 outras pessoas executaram este guia.
Roshni Sachar
Membro desde: 03/19/16
298 Reputação
Autoria de 1 guia
Equipe
15 comentários
Cat hair will jam up in the small gap between the gear and the bushing on the turbine and will cause enough friction to stop the turbine. I used a needle to dig out the hair and it solved the problem.
hvabrams - Responder
Great tip! It works now! TY!
Wendy Dean -
perfect solution, could find the problem
Pat Gustafson -
Thank you so much for posting this helpful advice… it was the perfect solution to fix exactly what was happening to stop the turbine on the brush accessory for my Shark vacuum. Because I couldn’t find info anywhere else, especially - and frustratingly - the manufacturer’s site, I almost ended up purchasing a replacement part. I so appreciate your suggestion here!
Elizabeth C Lewis -
very clear and concise. took me 5 minutes with your instructions - couldn’t find anything like this on the shark site.
tigersfoot - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 75
Últimos 30 dias: 322
Duração total: 45,709
