Ir para o conteúdo principal
Shark Ultimate Professional Mode Display Replacement
O que você precisa
  1. Shark Ultimate Professional Mode Display Replacement, Mode Display: passo 1, imagem 1 %32 Shark Ultimate Professional Mode Display Replacement, Mode Display: passo 1, imagem 2 %32 Shark Ultimate Professional Mode Display Replacement, Mode Display: passo 1, imagem 3 %32
    • Use the Philips head #0 screwdriver to remove the two 11.49mm screws at the back of the iron.
    • Remove the back cover piece.
    • Make sure the iron is unplugged and cooled off.
  2. Shark Ultimate Professional Mode Display Replacement: passo 2, imagem 1 %32 Shark Ultimate Professional Mode Display Replacement: passo 2, imagem 2 %32
    • Use the Philips head #0 screwdriver to remove the two 11.77mm screws holding the white clamp to the iron.
    • Use the Philips head #0 screwdriver to remove the two 6.58mm screws holding the black wires to the body of the iron.
    • Removing the left black wire will also free the red wire, attached by the same screw.
  3. Shark Ultimate Professional Mode Display Replacement: passo 3, imagem 1 %32 Shark Ultimate Professional Mode Display Replacement: passo 3, imagem 2 %32 Shark Ultimate Professional Mode Display Replacement: passo 3, imagem 3 %32
    • Pull the split end of the power cord upward through the ball joint of the iron.
    • Set aside the power cord.
  4. Shark Ultimate Professional Mode Display Replacement: passo 4, imagem 1 %32 Shark Ultimate Professional Mode Display Replacement: passo 4, imagem 2 %32 Shark Ultimate Professional Mode Display Replacement: passo 4, imagem 3 %32
    • Use the Philips head #0 screwdriver to remove remaining 6.58mm screws that hold a wire on the bottom (brown and blue).
    • Unscrew from left to right.
    • Wires order (from left to right): Brown, Blue, Black, Red
    • Unclip the black adapter piece on the bottom right.
  5. Shark Ultimate Professional Mode Display Replacement: passo 5, imagem 1 %32 Shark Ultimate Professional Mode Display Replacement: passo 5, imagem 2 %32
    • Use the Philips head #0 screwdriver to remove two 9.75mm screws (left and right) affixed to circuit board.
  6. Shark Ultimate Professional Mode Display Replacement: passo 6, imagem 1 %32 Shark Ultimate Professional Mode Display Replacement: passo 6, imagem 2 %32
    • Use the Philips head #0 screwdriver to remove the two 9.82mm screws (left and right) from the white border on top of the circuit board.
    • Pull the circuit board out from its affixed position.
  7. Shark Ultimate Professional Mode Display Replacement: passo 7, imagem 1 %32 Shark Ultimate Professional Mode Display Replacement: passo 7, imagem 2 %32 Shark Ultimate Professional Mode Display Replacement: passo 7, imagem 3 %32
    • Lift the handle and wiggle the plastic trim and the orange-chrome bezel out from under the handle.
    • Remove and set aside the mode display.
Conclusão
Uma outra pessoa concluiu este guia.
Drew Carff
Membro desde: 10/23/17
868 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G4, Leahy Fall 2017 Membro de USF Tampa, Team S1-G4, Leahy Fall 2017
USFT-LEAHY-F17S1G4
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 729
