Ir para o conteúdo principal
Shark Ultimate Professional Heat Plate Replacement
O que você precisa
  1. Shark Ultimate Professional Heat Plate Replacement, Heat Plate: passo 1, imagem 1 %32 Shark Ultimate Professional Heat Plate Replacement, Heat Plate: passo 1, imagem 2 %32 Shark Ultimate Professional Heat Plate Replacement, Heat Plate: passo 1, imagem 3 %32
    • Remove the two screws at the back of the iron.
    • Remove the back cover piece.
    • Make sure iron is unplugged and cooled off.
  2. Shark Ultimate Professional Heat Plate Replacement: passo 2, imagem 1 %32 Shark Ultimate Professional Heat Plate Replacement: passo 2, imagem 2 %32
    • Remove the two screws holding the white clamp to the iron.
    • Remove the two screws holding the black wires to the body of the iron.
    • Removing the left black wire will also free the red wire, attached by the same screw.
  3. Shark Ultimate Professional Heat Plate Replacement: passo 3, imagem 1 %32
    • Pull the split end of the power cord upward through the ball joint of the iron.
    • Set aside power cord.
  4. Shark Ultimate Professional Heat Plate Replacement: passo 4, imagem 1 %32 Shark Ultimate Professional Heat Plate Replacement: passo 4, imagem 2 %32 Shark Ultimate Professional Heat Plate Replacement: passo 4, imagem 3 %32
    • Remove remaining screws that hold a wire on the bottom (brown and blue).
    • Unscrew from left to right.
    • Unclip the black adapter piece on the bottom right.
    • Wires order (from left to right): Brown, Blue, Red, Black
  5. Shark Ultimate Professional Heat Plate Replacement: passo 5, imagem 1 %32 Shark Ultimate Professional Heat Plate Replacement: passo 5, imagem 2 %32
    • Remove two screws (left and right) affixed to circuit board.
Conclusão
3 outras pessoas executaram este guia.
Drew Carff
Membro desde: 10/23/17
868 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G4, Leahy Fall 2017 Membro de USF Tampa, Team S1-G4, Leahy Fall 2017
USFT-LEAHY-F17S1G4
Membros da 3
Autoria de 10 guias
3 comentários
This is an incomplete guide. Why even put it up. So silly and ridiculous. Not Good at all.
Muhammad Ahmad - Responder
Where is the part about the heat plate?
Nealy Moxam - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 2,452
