Ir para o conteúdo principal
Shark Steam Pocket Mop Steam Head Hose Replacement
O que você precisa
  1. Shark Steam Pocket Mop Steam Head Hose Replacement, Steam Head Hose: passo 1, imagem 1 %32 Shark Steam Pocket Mop Steam Head Hose Replacement, Steam Head Hose: passo 1, imagem 2 %32 Shark Steam Pocket Mop Steam Head Hose Replacement, Steam Head Hose: passo 1, imagem 3 %32
    • Start by removing this quarter inch Phillips head screw
    • Next remove the two 1/8th inch Phillips head screws at the bottom of the connector piece.
    • Next remove the nine 1/8th inch Phillips head screws along the base of the steam head connection.
    • Next remove the two 1/8th inch Phillips head screws along the base of the steam head connector.
  2. Shark Steam Pocket Mop Steam Head Hose Replacement: passo 2, imagem 1 %32 Shark Steam Pocket Mop Steam Head Hose Replacement: passo 2, imagem 2 %32 Shark Steam Pocket Mop Steam Head Hose Replacement: passo 2, imagem 3 %32
    • Once all the screws are removed and the baseplate of the steam head connection has been placed aside, gently remove the connector from the bottom of the base.
    • Gently remove the end caps of the hinge piece of the connector piece with your fingers.
    • Gently remove the host connection from the back plate.
    Is there a place I can buy the steam hose to replace? Mine has fallen apart but machine works fully otherwise!
    Amy - Responder
  3. Shark Steam Pocket Mop Steam Head Hose Replacement: passo 3, imagem 1 %32 Shark Steam Pocket Mop Steam Head Hose Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use your tweezers to remove the metal ring holding the hose to the plastic end piece and replace the hose / bit as needed.
    Where can I find a replacement hose? Can i use a plain silicone tubing?
    Helita Bauer - Responder
Conclusão
Uma outra pessoa concluiu este guia.
Jacob Howe
Membro desde: 10/10/17
549 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S13-G7, Cagle Fall 2017 Membro de USF Tampa, Team S13-G7, Cagle Fall 2017
USFT-CAGLE-F17S13G7
Membros da 4
Autoria de 10 guias
2 comentários
Ok, but where do I get a replacement hose?
semajrolyat - Responder
Same question as semajrolyat: where to source replacement hose?
CLIFTON CHANG - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 1,938
