Ir para o conteúdo principal
Shark Steam Pocket Mop Power Cable Replacement
O que você precisa
  1. Shark Steam Pocket Mop Power Cable Replacement, Back Panel: passo 1, imagem 1 %32 Shark Steam Pocket Mop Power Cable Replacement, Back Panel: passo 1, imagem 2 %32 Shark Steam Pocket Mop Power Cable Replacement, Back Panel: passo 1, imagem 3 %32
    • Begin by removing the 8 quarter inch phillips head screws found along the back panel
    • Once all 8 screws have been removed, gently remove the back panel from the rest of the mop's body
  2. Shark Steam Pocket Mop Power Cable Replacement, Power Cable: passo 2, imagem 1 %32 Shark Steam Pocket Mop Power Cable Replacement, Power Cable: passo 2, imagem 2 %32
    • Start by removing the two 1/8th inch Phillips head screws with your Phillips head screwdriver.
    • Gently remove the small plastic piece holding the wires against the plastic midframe of the mop.
    • Next use your wire cutters to remove the two plastic connectors and replace those wires with your new ones.
Conclusão
Jacob Howe
Membro desde: 10/10/17
549 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S13-G7, Cagle Fall 2017 Membro de USF Tampa, Team S13-G7, Cagle Fall 2017
USFT-CAGLE-F17S13G7
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 21
Duração total: 1,645
