Ir para o conteúdo principal
Shark Steam Pocket Mop Ejection Button Assembly Replacement
O que você precisa
  1. Shark Steam Pocket Mop Ejection Button Assembly Replacement, Back Panel: passo 1, imagem 1 %32 Shark Steam Pocket Mop Ejection Button Assembly Replacement, Back Panel: passo 1, imagem 2 %32 Shark Steam Pocket Mop Ejection Button Assembly Replacement, Back Panel: passo 1, imagem 3 %32
    • Begin by removing the 8 quarter inch phillips head screws found along the back panel
    • Once all 8 screws have been removed, gently remove the back panel from the rest of the mop's body
  2. Shark Steam Pocket Mop Ejection Button Assembly Replacement, Ejection Button Assembly: passo 2, imagem 1 %32 Shark Steam Pocket Mop Ejection Button Assembly Replacement, Ejection Button Assembly: passo 2, imagem 2 %32 Shark Steam Pocket Mop Ejection Button Assembly Replacement, Ejection Button Assembly: passo 2, imagem 3 %32
    • Begin by removing the two quarter inch Phillips head screws you see pictured. These screws hold the bottom part of the button assembly to the Mop's midframe.
    • Be very careful not to lose the spring that is in between the top and bottom part of the button assembly.
  3. Shark Steam Pocket Mop Ejection Button Assembly Replacement: passo 3, imagem 1 %32 Shark Steam Pocket Mop Ejection Button Assembly Replacement: passo 3, imagem 2 %32
    • Once the bottom piece of the assembly has been removed, carefully turn the mop over and move the front panel of the mop to the side
    • Once you've turned your device over you should be able to remove the top portion of the button assembly with ease. It should not require anything more than your fingers.
Conclusão
Uma outra pessoa concluiu este guia.
Jacob Howe
Membro desde: 10/10/17
549 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S13-G7, Cagle Fall 2017 Membro de USF Tampa, Team S13-G7, Cagle Fall 2017
USFT-CAGLE-F17S13G7
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 291
