Ir para o conteúdo principal
Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement
O que você precisa
  1. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement, Roller Brush: passo 1, imagem 1 %32 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement, Roller Brush: passo 1, imagem 2 %32
    • Push the red Lift Away button down and lift up on the vacuum handle to detach the base.
    • The handle was removed for convenience but is not required.
  2. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: passo 2, imagem 1 %32
    • Turn over the vacuum to reveal the roller brush.
  3. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: passo 3, imagem 1 %32 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: passo 3, imagem 2 %32
    • Pry the small wheels at the bottom of the base using the plastic opening tool.
  4. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: passo 4, imagem 1 %32 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: passo 4, imagem 2 %32
    • Using a coin, turn the big white knobs located above the roller brush counter-clockwise.
  5. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: passo 5, imagem 1 %32 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: passo 5, imagem 2 %32 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: passo 5, imagem 3 %32
    • Lift up the suction hose to reveal a screw.
    • Remove the 12.7 mm Phillips #02 screw.
  6. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: passo 6, imagem 1 %32 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: passo 6, imagem 2 %32
    • Remove eight 12.7mm screws located under the vacuum using a Phillips #02 screwdriver.
    • Remove two 12.7 mm screws located next to the wheels with a Phillips #02 screwdriver.
    • The two screws located next to the wheels are smaller in diameter.
  7. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: passo 7, imagem 1 %32 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: passo 7, imagem 2 %32 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: passo 7, imagem 3 %32
    • Turn the vacuum upright and pull the white upper section of the brush roller circuit housing.
    • Be careful when lifting the housing as there is a connector attached.
  8. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: passo 8, imagem 1 %32 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: passo 8, imagem 2 %32
    • Remove the connector attached to the circuit boards using a plastic opening tool.
  9. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: passo 9, imagem 1 %32 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: passo 9, imagem 2 %32 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: passo 9, imagem 3 %32
    • Remove the two 12.7 mm screws located at the top of the clear plastic brush roller housing using a Phillips #02 screwdriver.
    • Lift the clear plastic brush roller housing.
  10. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: passo 10, imagem 1 %32 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: passo 10, imagem 2 %32
    • Wiggle the brush roller upwards from the left and right side slots.
  11. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement, Roller Brush Belt: passo 11, imagem 1 %32
    • Remove the roller brush by sliding it out toward the left, off the belt.
  12. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: passo 12, imagem 1 %32
    • Remove the belt from the motor gear by sliding the belt away from the gear and belt motor.
    • In the following picture the belt was already removed.
Conclusão
Daniel Ceja
Membro desde: 01/24/19
277 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S19-G3, White Winter 2019 Membro de Cal Poly, Team S19-G3, White Winter 2019
CPSU-WHITE-W19S19G3
Membros da 5
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 556
