Ir para o conteúdo principal
Shark Rotator Slim-Light Lift-Away Upright Motor Replacement
O que você precisa
  1. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement, Motor: passo 1, imagem 1 %32 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement, Motor: passo 1, imagem 2 %32
    • Push the red Lift Away button down and lift up on the vacuum handle to detach the base.
    • The handle was removed for convenience but is not required.
  2. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: passo 2, imagem 1 %32 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: passo 2, imagem 2 %32 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: passo 2, imagem 3 %32
    • Remove the two 19mm Phillips #2 screws located in the red plastic piece behind the filter.
  3. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: passo 3, imagem 1 %32 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: passo 3, imagem 2 %32 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: passo 3, imagem 3 %32
    • Flip over vacuum and remove the six 12.7mm Phillips #2 screws from the base.
    • Take off white plastic cover exposing the motor in its insulation.
  4. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: passo 4, imagem 1 %32 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: passo 4, imagem 2 %32 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: passo 4, imagem 3 %32
    • Remove the motor from the base and slide the insulation down along the wires.
    • Find the plastic caps on top of the black and white wires. Using pliers twist and carefully remove these caps.
    • Needle nosed pliers are recommended but not necessary.
    • These plastic caps are somewhat sensitive and can be difficult to take off. Additionally once taken off they can become unusable.
Conclusão
Uma outra pessoa concluiu este guia.
Joshua Morrison
Membro desde: 01/24/19
196 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S19-G3, White Winter 2019 Membro de Cal Poly, Team S19-G3, White Winter 2019
CPSU-WHITE-W19S19G3
Membros da 5
Autoria de 12 guias
Um comentário
What is the motor PN and where can I get one?
Dennis Meece - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 33
Duração total: 1,447
