Ir para o conteúdo principal
Shark Rotator Lift-Away Speed Filter Replacement
  1. Shark Rotator Lift-Away Speed Filter Replacement, Filter: passo 1, imagem 1 %32 Shark Rotator Lift-Away Speed Filter Replacement, Filter: passo 1, imagem 2 %32 Shark Rotator Lift-Away Speed Filter Replacement, Filter: passo 1, imagem 3 %32
    • Make sure the vacuum is turned off and unplugged before proceeding.
    • Lay the vacuum pod flat with the bottom facing towards you.
    • Pull the silver release latch and lift away from the body of the vacuum from the bottom.
  2. Shark Rotator Lift-Away Speed Filter Replacement: passo 2, imagem 1 %32
    • Lift the front cover off the face of the vacuum body.
    • Pull out the filter.
    • This filter should be replaced or washed once a year.
  3. Shark Rotator Lift-Away Speed Filter Replacement: passo 3, imagem 1 %32 Shark Rotator Lift-Away Speed Filter Replacement: passo 3, imagem 2 %32 Shark Rotator Lift-Away Speed Filter Replacement: passo 3, imagem 3 %32
    • Rest the vacuum pod upright.
    • Press down on the buttons on either side of the handle labeled “dust cup release.”
    • Lift the dust cup away from from the body of the vacuum to uncover the foam filter.
    • In most Shark manuals, the vacuum pod is referred to as the "Lift-Away Pod."
  4. Shark Rotator Lift-Away Speed Filter Replacement: passo 4, imagem 1 %32 Shark Rotator Lift-Away Speed Filter Replacement: passo 4, imagem 2 %32
    • Lift the foam filter and filter frame out of the center of the vacuum to unveil the felt filter.
    • Remove the felt filter by lifting the pull-tab.
    • These filters should be replaced or washed every three months.
    • Do not use the vacuum without the dust cup and filters in place.
Conclusão
Julia Sullivan
Membro desde: 10/02/17
107 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S15-G7, Livingston Fall 2017 Membro de Cal Poly, Team S15-G7, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G7
Membros da 4
Autoria de 10 guias
3 comentários
I cleaned all filters vacuum a rug and then went to regular floors and the vacuum stopped all together I don't know what it is belt looks new
donnaweitz4849@gmail.com - Responder
I cleaned all filters let them dry then replaced to vacuum started vacuum and it ran less than 5minutes and it shut down
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 18
Últimos 30 dias: 92
Duração total: 10,794
