Ir para o conteúdo principal
Shark Rotator Lift-Away Speed Brushroll Replacement
O que você precisa
  1. Shark Rotator Lift-Away Speed Brushroll Replacement, Brushroll: passo 1, imagem 1 %32
    • Make sure the vacuum is turned off and unplugged before proceeding.
    • Locate the release button at the top of the vacuum pod next to the handle.
    • Use the handle to lift the pod up off of the vacuum nozzle while pressing the release button.
    • Removing the pod is optional, but it may be easier to locate blockages or access the motor and belt if you do so.
  2. Shark Rotator Lift-Away Speed Brushroll Replacement: passo 2, imagem 1 %32 Shark Rotator Lift-Away Speed Brushroll Replacement: passo 2, imagem 2 %32
    • Press the Brushroll Access buttons on the top of the nozzle to reveal the brushroll compartment.
  3. Shark Rotator Lift-Away Speed Brushroll Replacement: passo 3, imagem 1 %32 Shark Rotator Lift-Away Speed Brushroll Replacement: passo 3, imagem 2 %32
    • Lift the brushroll out by using the pull-tab on the left side.
    • You can test the brushroll once it has been inserted by plugging the vacuum in and running the vacuum in carpet mode. The brushroll indicator light should be a solid green color.
Conclusão
Weston Mongomery
Membro desde: 10/02/17
201 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S15-G7, Livingston Fall 2017 Membro de Cal Poly, Team S15-G7, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G7
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 1,810
