Ir para o conteúdo principal
Shark Rocket Professional Floor Hose Replacement
O que você precisa
  1. Shark Rocket Professional Floor Hose Replacement, Floor Hose: passo 1, imagem 1 %32 Shark Rocket Professional Floor Hose Replacement, Floor Hose: passo 1, imagem 2 %32
    • Look at the side of your vacuum.
    • Identify the button that says "Floor Nozzle."
    • Press this button and remove the main body of the vacuum.
  2. Shark Rocket Professional Floor Hose Replacement: passo 2, imagem 1 %32 Shark Rocket Professional Floor Hose Replacement: passo 2, imagem 2 %32 Shark Rocket Professional Floor Hose Replacement: passo 2, imagem 3 %32
    • Look at the bottom of the Floor Nozzle.
    • Use a coin to turn the orange locking dials counter-clockwise.
    • If you are unsure, follow the arrows when turning the orange dials because the labeling is confusing.
  3. Shark Rocket Professional Floor Hose Replacement: passo 3, imagem 1 %32
    • Use your fingers to pull open the panel locked by the orange mechanism.
    • If there is debris stuck in the tube, use a long, thin object to remove it.
Conclusão
Brad Iglesia
Membro desde: 01/24/18
316 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S18-G6, Livingston Winter 2018 Membro de Cal Poly, Team S18-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G6
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 28
Duração total: 4,923
