Ir para o conteúdo principal
Shark Rocket Professional Dust Cup Replacement
  1. Shark Rocket Professional Dust Cup Replacement, Dust Cup: passo 1, imagem 1 %32 Shark Rocket Professional Dust Cup Replacement, Dust Cup: passo 1, imagem 2 %32
    • First, locate the button that says "Dust Cup". It is right next to the power button at the base of the handle.
    • Press the button down completely; you should feel a click.
  2. Shark Rocket Professional Dust Cup Replacement: passo 2, imagem 1 %32
    • Grab the handle of the dust cup, then pull up and away from the vacuum.
    • You must press the button and pull the dust cap simultaneously at first to release the latch.
Conclusão
Uma outra pessoa concluiu este guia.
Theo Watkins
Membro desde: 01/23/18
356 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S18-G6, Livingston Winter 2018 Membro de Cal Poly, Team S18-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G6
Membros da 4
Autoria de 10 guias
2 comentários
And what do you do if the dust cup button is stuck and won’t depress????
Susan Berlin - Responder
need replacement bucket NV830
BETTIE LABUDA - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 73
Duração total: 3,579
