Introdução
Dust will build up on the filter over time and block the airway, which will reduce the efficiency of the machine. This guide will show you how to replace a dirty or old Post-Motor Filter on your Shark Rocket Powerhead AH401.
O que você precisa
Push down on the dust can lever to release the dust can in order to get to the filter grill.
Push inward on the top of the filter grille where it says "Push."
Lift the filter grille upward.
Remove the filter by pulling it out and away from the device with your hand.
Uma outra pessoa concluiu este guia.
