Ir para o conteúdo principal
Shark Rocket Powerhead AH401 Post-Motor Filter Replacement
O que você precisa
  1. Shark Rocket Powerhead AH401 Post-Motor Filter Replacement, Dust Cup: passo 1, imagem 1 %32 Shark Rocket Powerhead AH401 Post-Motor Filter Replacement, Dust Cup: passo 1, imagem 2 %32 Shark Rocket Powerhead AH401 Post-Motor Filter Replacement, Dust Cup: passo 1, imagem 3 %32
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Push down on the dust can lever to release the dust can in order to get to the filter grill.
  2. Shark Rocket Powerhead AH401 Post-Motor Filter Replacement: passo 2, imagem 1 %32 Shark Rocket Powerhead AH401 Post-Motor Filter Replacement: passo 2, imagem 2 %32
    • Remove the dust cup by lifting it off the dock.
  3. Shark Rocket Powerhead AH401 Post-Motor Filter Replacement, Filter Grille: passo 3, imagem 1 %32 Shark Rocket Powerhead AH401 Post-Motor Filter Replacement, Filter Grille: passo 3, imagem 2 %32
    • Push inward on the top of the filter grille where it says "Push."
    • Lift the filter grille upward.
  4. Shark Rocket Powerhead AH401 Post-Motor Filter Replacement: passo 4, imagem 1 %32 Shark Rocket Powerhead AH401 Post-Motor Filter Replacement: passo 4, imagem 2 %32
    • Lift gently and pull the grille up towards you until it releases.
    • The post-motor filter is underneath the filter grille.
  5. Shark Rocket Powerhead AH401 Post-Motor Filter Replacement, Post-Motor Filter: passo 5, imagem 1 %32 Shark Rocket Powerhead AH401 Post-Motor Filter Replacement, Post-Motor Filter: passo 5, imagem 2 %32
    • Remove the filter by pulling it out and away from the device with your hand.
Conclusão
Uma outra pessoa concluiu este guia.
Shobhit Dabral
Membro desde: 01/24/18
901 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team S19-G3, Livingston Winter 2018 Membro de Cal Poly, Team S19-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G3
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 635
