Ir para o conteúdo principal
Shark Rocket Powerhead AH401 Panel Screws Replacement
O que você precisa
  1. Shark Rocket Powerhead AH401 Panel Screws Replacement, Brushroll: passo 1, imagem 1 %32 Shark Rocket Powerhead AH401 Panel Screws Replacement, Brushroll: passo 1, imagem 2 %32 Shark Rocket Powerhead AH401 Panel Screws Replacement, Brushroll: passo 1, imagem 3 %32
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
    • Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
    • Lift the brushroll cover upward.
  2. Shark Rocket Powerhead AH401 Panel Screws Replacement: passo 2, imagem 1 %32 Shark Rocket Powerhead AH401 Panel Screws Replacement: passo 2, imagem 2 %32
    • Lift the brushroll out by pulling the tab labeled "pull".
  3. Shark Rocket Powerhead AH401 Panel Screws Replacement, Dust Cup: passo 3, imagem 1 %32 Shark Rocket Powerhead AH401 Panel Screws Replacement, Dust Cup: passo 3, imagem 2 %32 Shark Rocket Powerhead AH401 Panel Screws Replacement, Dust Cup: passo 3, imagem 3 %32
    • Push down on the dust can lever to release the dust can in order to get to the filter grill.
  4. Shark Rocket Powerhead AH401 Panel Screws Replacement: passo 4, imagem 1 %32 Shark Rocket Powerhead AH401 Panel Screws Replacement: passo 4, imagem 2 %32
    • Remove the dust cup by lifting it off the dock.
  5. Shark Rocket Powerhead AH401 Panel Screws Replacement, Back Panel Screws: passo 5, imagem 1 %32 Shark Rocket Powerhead AH401 Panel Screws Replacement, Back Panel Screws: passo 5, imagem 2 %32
    • Flip the device over so that the bottom is face up.
    • Remove the eight screws shown by rotating counter-clockwise with a T15 Torx screwdriver.
    • Two 14 mm Torx screws
    • Two 16 mm Torx screws
    • Four 21 mm Torx screws
Conclusão
Toan Pham
Membro desde: 01/24/18
269 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S19-G3, Livingston Winter 2018 Membro de Cal Poly, Team S19-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G3
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 967
