Introdução
If one of the components on the motherboard is damaged, it is easier to replace the whole motherboard. Gaining access to the motherboard requires disassembling the vacuum. This guide will demonstrate how to remove the motherboard of your Shark Rocket Powerhead AH401.
Peças
Não são necessárias peças.
  1. Ensure the device is turned off and unplugged from any power source before beginning work. Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover. Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
    • Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
    • Lift the brushroll cover upward.
  2. Lift the brushroll out by pulling the tab labeled "pull". Lift the brushroll out by pulling the tab labeled "pull".
    • Lift the brushroll out by pulling the tab labeled "pull".
  3. Ensure the device is turned off and unplugged from any power source before beginning work. Push down on the dust can lever to release the dust can in order to get to the filter grill. Push down on the dust can lever to release the dust can in order to get to the filter grill.
    • Push down on the dust can lever to release the dust can in order to get to the filter grill.
  4. Remove the dust cup by lifting it off the dock. Remove the dust cup by lifting it off the dock.
    • Remove the dust cup by lifting it off the dock.
  5. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  6. Flip the device over so that the bottom is face up. Remove the eight screws shown by rotating counter-clockwise with a T15 Torx screwdriver.
    • Flip the device over so that the bottom is face up.
    • Remove the eight screws shown by rotating counter-clockwise with a T15 Torx screwdriver.
      • Two 14 mm Torx screws
      • Two 16 mm Torx screws
      • Four 21 mm Torx screws
  7. Remove the three 10mm screws by rotating counter clockwise with a T15 Torx screwdriver. Remove the airpath grille by gently lifting up and away from the motor compartment. Remove the airpath grille by gently lifting up and away from the motor compartment.
    • Remove the three 10mm screws by rotating counter clockwise with a T15 Torx screwdriver.
    • Remove the airpath grille by gently lifting up and away from the motor compartment.
  8. Remove two 14mm screws by rotating counter-clockwise with a T15 Torx screwdriver.
    • Remove two 14mm screws by rotating counter-clockwise with a T15 Torx screwdriver.
  9. Lift and gently remove the hinge compartment covering the motherboard. Lift and gently remove the hinge compartment covering the motherboard. Lift and gently remove the hinge compartment covering the motherboard.
    • Lift and gently remove the hinge compartment covering the motherboard.
  10. Remove the two 10mm screws by rotating counter-clockwise with a T10 Torx screwdriver
    • Remove the two 10mm screws by rotating counter-clockwise with a T10 Torx screwdriver
  11. Lift the motherboard out of its compartment. Lift the motherboard out of its compartment.
    • Lift the motherboard out of its compartment.
  12. Locate and remove these connections by pulling the plugs out of the sockets. Locate and remove these connections by pulling the plugs out of the sockets. Locate and remove these connections by pulling the plugs out of the sockets.
    • Locate and remove these connections by pulling the plugs out of the sockets.
  13. Flip the motherboard over to reveal the wires underneath. Locate and cut all the wires connected to the motherboard using cutting pliers. Locate and cut all the wires connected to the motherboard using cutting pliers.
    • Flip the motherboard over to reveal the wires underneath.
    • Locate and cut all the wires connected to the motherboard using cutting pliers.
Conclusão
Shobhit Dabral
763 reputação
6 Guides authored
Equipe
Cal Poly, Team S19-G3, Livingston Winter 2018 Membro de Cal Poly, Team S19-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G3
4 Membros
9 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Todo: 103
