Introdução
This guide will show you how to replace the filter grille if it becomes damaged, does not remain in place, or if you need to reach the Post-Motor filter.
Ferramentas
Não são necessárias ferramentas.
Peças
  1. Ensure the device is turned off and unplugged from any power source before beginning work. Push down on the dust can lever to release the dust can in order to get to the filter grill. Push down on the dust can lever to release the dust can in order to get to the filter grill.
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Push down on the dust can lever to release the dust can in order to get to the filter grill.
  2. Remove the dust cup by lifting it off the dock. Remove the dust cup by lifting it off the dock.
    • Remove the dust cup by lifting it off the dock.
  3. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. Push inward on the top of the filter grille where it says "Push." Lift the filter grille upward.
    • Push inward on the top of the filter grille where it says "Push."
    • Lift the filter grille upward.
  5. Lift gently and pull the grille up towards you until it releases. The post-motor filter is underneath the filter grille.
    • Lift gently and pull the grille up towards you until it releases.
    • The post-motor filter is underneath the filter grille.
Conclusão
Shobhit Dabral
763 reputação
6 Guides authored
Equipe
Cal Poly, Team S19-G3, Livingston Winter 2018 Membro de Cal Poly, Team S19-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G3
4 Membros
9 Guides authored
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Todo: 82
