Ir para o conteúdo principal
Shark Rocket Powerhead AH401 Brushroll Cap Replacement
  1. Shark Rocket Powerhead AH401 Brushroll Cap Replacement, Brushroll: passo 1, imagem 1 %32 Shark Rocket Powerhead AH401 Brushroll Cap Replacement, Brushroll: passo 1, imagem 2 %32 Shark Rocket Powerhead AH401 Brushroll Cap Replacement, Brushroll: passo 1, imagem 3 %32
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
    • Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
    • Lift the brushroll cover upward.
  2. Shark Rocket Powerhead AH401 Brushroll Cap Replacement: passo 2, imagem 1 %32 Shark Rocket Powerhead AH401 Brushroll Cap Replacement: passo 2, imagem 2 %32
    • Lift the brushroll out by pulling the tab labeled "pull".
  3. Shark Rocket Powerhead AH401 Brushroll Cap Replacement, Brushroll Cap: passo 3, imagem 1 %32 Shark Rocket Powerhead AH401 Brushroll Cap Replacement, Brushroll Cap: passo 3, imagem 2 %32 Shark Rocket Powerhead AH401 Brushroll Cap Replacement, Brushroll Cap: passo 3, imagem 3 %32
    • Remove the cap by pushing the "pull" tab.
Conclusão
Shobhit Dabral
Membro desde: 01/24/18
901 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team S19-G3, Livingston Winter 2018 Membro de Cal Poly, Team S19-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G3
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 946
