Ir para o conteúdo principal
Shark Rocket HV381 Brush Replacement
  1. Shark Rocket HV381 Brush Replacement, Brush: passo 1, imagem 1 %32 Shark Rocket HV381 Brush Replacement, Brush: passo 1, imagem 2 %32
    • On the top of the vacuum head is two grey "Brush Roller Access" buttons. Simultaneously press both buttons to eject the Roller Cover. Remove the Roller Cover by pulling it towards you and up.
  2. Shark Rocket HV381 Brush Replacement: passo 2, imagem 1 %32 Shark Rocket HV381 Brush Replacement: passo 2, imagem 2 %32 Shark Rocket HV381 Brush Replacement: passo 2, imagem 3 %32
    • The "Pull Tab" tab is located at the right. Pull the Tab up and to the right for removal.
    • The Brush is sticky so hold the vacuum head with one hand and give the tab a moderate tug.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 6
Últimos 30 dias: 12
Duração total: 696
