Introdução
This guide is to help consumers remove the rotary belt from their Shark rocket HV301. Be sure to have the proper tools and replacement parts available prior to beginning this guide.
O que você precisa
Flip the vacuum so the bottom base is visible.
Gently pry the bottom two wheels off with a plastic opening tool.
15 outras pessoas executaram este guia.
3 comentários
Where can I find the rotary belt for the Shark Duo?
I could not get it out without removing the brush roll motor. So I am putting it back together and I need to know if the motor has a top and bottom. What I mean is does it matter ? Thank you
Thanks for the guide it came in super handy
