Ir para o conteúdo principal
Shark Professional Steam Pocket Mop Steam Nozzle Replacement
O que você precisa
  1. Shark Professional Steam Pocket Mop Steam Nozzle Replacement, Steam Nozzle: passo 1, imagem 1 %32
    • Press the mop head release button to remove it from the steam mop body.
  2. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: passo 2, imagem 1 %32
    • Remove the four 10mm screws holding the joint assembly to the mop head with your Phillips #2 screwdriver.
  3. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: passo 3, imagem 1 %32
    • Remove the two plastic hinge covers by pulling the hinges out of the joint and sliding the covers off.
  4. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: passo 4, imagem 1 %32
    • Stretch joint assembly forward to expose two 11mm Phillips #2 screws on either side of the steam tube.
    • Remove both screws.
  5. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: passo 5, imagem 1 %32
    • Lift joint assembly out of hinge socket and pull upward with mild force to disconnect steam nozzle.
  6. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: passo 6, imagem 1 %32
    • Use needle nose pliers to compress metal clamp .
  7. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: passo 7, imagem 1 %32
    • Pull the nozzle out of the tube.
Conclusão
Uma outra pessoa concluiu este guia.
Michael Raymond
Membro desde: 02/12/18
154 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S15-G1, Boczar Spring 2018 Membro de USF Tampa, Team S15-G1, Boczar Spring 2018
USFT-BOCZAR-S18S15G1
Membros da 4
Autoria de 14 guias
2 comentários
This was fantastic. Only place I found on how to disassemble mop head. If i were you, I would go a little further and explain how to clean the nozzle. Use a paper clip or 20 gauge wire to push build up out. If that does not work use a small drill bit ( be careful to drill straight or you could damage the wall or jacket . This worked for me. Saved me $30. Had a problem locating this sight. Maybe some way to make it easier to locate would help. Thanks for your posting.
Mike Cunningham - Responder
Do you know if I can soak this part in clr? I can't seem to clean it well enough.
Kelsey Harper -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 21
Últimos 30 dias: 69
Duração total: 4,409
