Introdução
Of all the parts to replace on the Shark Pro Steam Pocket Mop, the heating element is likely the trickiest to replace since it's at the core of the mop. Nonetheless, this guide will make the process a breeze. As always, before doing any disassembly on your Shark Professional Steam Pocket Mop, make sure to unplug the mop and empty the water tank for your safety.
O que você precisa
Unwrap the power cord from the handle.
Remove the 56.0 mm Phillips head #2 screw located above the water tank cap.
Pull the handle to separate it from the body.
Remove steam control button cover with a metal spudger.
Remove the two 12.0 mm Phillips head #2 screws underneath.
Remove the plastic rim with clear plastic cover.
Remove the three 12.0 mm Philips head #2 screws connected to the dark grey plastic trim.
Remove the four 12.0 mm Phillips head #2 screws on the sides of the heating element.
Pull apart wire connectors to fully detach the heating element.
Do you replace the element or are you saying once you detach you go ahead and reattach the same element
3 outras pessoas executaram este guia.
6 comentários
Is the heating element available somewhere? I cannot find it anywhere.
Where can the heating element be purchased in order to replace? Can’t find anywhere.
i have a shark s3973d. and i need a heating elementand the two hosese connected
to the heating element. if no heating element. would like to order the hoses.
Once element is detached where do I get a new one
I just bought this shark steam vac less than 6months ago
