Ir para o conteúdo principal
Shark Professional Steam Pocket Mop Heating Element Replacement
O que você precisa
  1. Shark Professional Steam Pocket Mop Heating Element Replacement, Shark Professional Steam Pocket Mop Front Panel Disassembly: passo 1, imagem 1 %32 Shark Professional Steam Pocket Mop Heating Element Replacement, Shark Professional Steam Pocket Mop Front Panel Disassembly: passo 1, imagem 2 %32
    • Unwrap the power cord from the handle.
    • Remove the 56.0 mm Phillips head #2 screw located above the water tank cap.
    • Pull the handle to separate it from the body.
  2. Shark Professional Steam Pocket Mop Heating Element Replacement: passo 2, imagem 1 %32 Shark Professional Steam Pocket Mop Heating Element Replacement: passo 2, imagem 2 %32 Shark Professional Steam Pocket Mop Heating Element Replacement: passo 2, imagem 3 %32
    • Remove the three 12.0 mm Phillips head #2 screws where the handle connects to the body.
    • Remove the plastic cap.
  3. Shark Professional Steam Pocket Mop Heating Element Replacement: passo 3, imagem 1 %32 Shark Professional Steam Pocket Mop Heating Element Replacement: passo 3, imagem 2 %32
    • Remove the three 16.0 mm T10 Torx screws near the top of the body and remove the water tank cap.
    • The third screw is directly on other side of the bottom screw in the photo.
  4. Shark Professional Steam Pocket Mop Heating Element Replacement: passo 4, imagem 1 %32 Shark Professional Steam Pocket Mop Heating Element Replacement: passo 4, imagem 2 %32 Shark Professional Steam Pocket Mop Heating Element Replacement: passo 4, imagem 3 %32
    • Remove steam control button cover with a metal spudger.
    • Remove the two 12.0 mm Phillips head #2 screws underneath.
    • Remove the plastic rim with clear plastic cover.
  5. Shark Professional Steam Pocket Mop Heating Element Replacement: passo 5, imagem 1 %32 Shark Professional Steam Pocket Mop Heating Element Replacement: passo 5, imagem 2 %32 Shark Professional Steam Pocket Mop Heating Element Replacement: passo 5, imagem 3 %32
    • Remove the Shark logo decal on the front of body using a metal spudger.
    • Pull out the plastic cover to remove.
  6. Shark Professional Steam Pocket Mop Heating Element Replacement: passo 6, imagem 1 %32
    • Pop off the grey front plate to expose the control panel and screws necessary to open mop body.
  7. Shark Professional Steam Pocket Mop Heating Element Replacement, Shark Professional Steam Pocket Mop Open Mop Body: passo 7, imagem 1 %32
    • Remove the three 12.0 mm Philips head #2 screws connected to the dark grey plastic trim.
  8. Shark Professional Steam Pocket Mop Heating Element Replacement: passo 8, imagem 1 %32
    • Remove the four 16.0 mm T10 Torx screws located on the back of the mop.
  9. Shark Professional Steam Pocket Mop Heating Element Replacement: passo 9, imagem 1 %32
    • Remove the two 12.0 mm Phillips head #2 screws that hold the power cord to the device.
  10. Shark Professional Steam Pocket Mop Heating Element Replacement: passo 10, imagem 1 %32
    • Pop off the dark grey plastic trim cover.
  11. Shark Professional Steam Pocket Mop Heating Element Replacement: passo 11, imagem 1 %32
    • Pop open the white plastic mop body by pulling apart from the front and back side.
  12. Shark Professional Steam Pocket Mop Heating Element Replacement, Heating Element: passo 12, imagem 1 %32
    • Remove the four 12.0 mm Phillips head #2 screws on the sides of the heating element.
  13. Shark Professional Steam Pocket Mop Heating Element Replacement: passo 13, imagem 1 %32 Shark Professional Steam Pocket Mop Heating Element Replacement: passo 13, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Pull out the heating element and use precision tweezers or pliers to pinch and loosen the two clamps.
    • Remove both tubes from the heating element.
  14. Shark Professional Steam Pocket Mop Heating Element Replacement: passo 14, imagem 1 %32
    • Grip each wire at its base and pull to disconnect them from the heating element.
  15. Shark Professional Steam Pocket Mop Heating Element Replacement: passo 15, imagem 1 %32
    • Remove two 12.0 mm Phillips head #2 screws from the heating element.
  16. Shark Professional Steam Pocket Mop Heating Element Replacement: passo 16, imagem 1 %32
    • Pull apart wire connectors to fully detach the heating element.
Conclusão
3 outras pessoas executaram este guia.
Brett Wilson
Membro desde: 02/12/18
992 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S15-G1, Boczar Spring 2018 Membro de USF Tampa, Team S15-G1, Boczar Spring 2018
USFT-BOCZAR-S18S15G1
Membros da 4
Autoria de 14 guias
6 comentários
Is the heating element available somewhere? I cannot find it anywhere.
Mark Cashion - Responder
Where can the heating element be purchased in order to replace? Can’t find anywhere.
Amanda Krusenstjerna - Responder
i have a shark s3973d. and i need a heating elementand the two hosese connected
to the heating element. if no heating element. would like to order the hoses.
RICHARD MARTINEZ - Responder
Once element is detached where do I get a new one
Sandra R Pannell - Responder
I just bought this shark steam vac less than 6months ago
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 27
Últimos 30 dias: 145
Duração total: 5,875
