Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Shark Professional Steam Pocket Mop, use o nosso manual de serviço.
  1. Shark Professional Steam Pocket Mop Front Panel Disassembly, Shark Professional Steam Pocket Mop Front Panel Disassembly: passo 1, imagem 1 %32 Shark Professional Steam Pocket Mop Front Panel Disassembly, Shark Professional Steam Pocket Mop Front Panel Disassembly: passo 1, imagem 2 %32
    • Unwrap the power cord from the handle.
    • Remove the 56.0 mm Phillips head #2 screw located above the water tank cap.
    • Pull the handle to separate it from the body.
  2. Shark Professional Steam Pocket Mop Front Panel Disassembly: passo 2, imagem 1 %32 Shark Professional Steam Pocket Mop Front Panel Disassembly: passo 2, imagem 2 %32 Shark Professional Steam Pocket Mop Front Panel Disassembly: passo 2, imagem 3 %32
    • Remove the three 12.0 mm Phillips head #2 screws where the handle connects to the body.
    • Remove the plastic cap.
  3. Shark Professional Steam Pocket Mop Front Panel Disassembly: passo 3, imagem 1 %32 Shark Professional Steam Pocket Mop Front Panel Disassembly: passo 3, imagem 2 %32
    • Remove the three 16.0 mm T10 Torx screws near the top of the body and remove the water tank cap.
    • The third screw is directly on other side of the bottom screw in the photo.
  4. Shark Professional Steam Pocket Mop Front Panel Disassembly: passo 4, imagem 1 %32 Shark Professional Steam Pocket Mop Front Panel Disassembly: passo 4, imagem 2 %32 Shark Professional Steam Pocket Mop Front Panel Disassembly: passo 4, imagem 3 %32
    • Remove steam control button cover with a metal spudger.
    • Remove the two 12.0 mm Phillips head #2 screws underneath.
    • Remove the plastic rim with clear plastic cover.
  5. Shark Professional Steam Pocket Mop Front Panel Disassembly: passo 5, imagem 1 %32 Shark Professional Steam Pocket Mop Front Panel Disassembly: passo 5, imagem 2 %32 Shark Professional Steam Pocket Mop Front Panel Disassembly: passo 5, imagem 3 %32
    • Remove the Shark logo decal on the front of body using a metal spudger.
    • Pull out the plastic cover to remove.
  6. Shark Professional Steam Pocket Mop Front Panel Disassembly: passo 6, imagem 1 %32
    • Pop off the grey front plate to expose the control panel and screws necessary to open mop body.
Brett Wilson
Membro desde: 02/12/18
992 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S15-G1, Boczar Spring 2018 Membro de USF Tampa, Team S15-G1, Boczar Spring 2018
USFT-BOCZAR-S18S15G1
Membros da 4
Autoria de 14 guias
Um comentário
Here is a video to help with dismantling if you'd like to see the possible original guide first posted on YouTube by George Robles September 16, 2015 years before.
https://youtu.be/18mMbbMjqzs
No one knew or posted before me because I looked everywhere and why I created the video.
But I am curious where you got your information from if it was not my video.
George Robles - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 98
Duração total: 3,938
