Introdução
If the indicator lights don't appear to be functioning despite being plugged in, a faulty control panel might be the culprit. Before doing any repair/disassembly on your Shark Professional Steam Pocket Mop, make sure to unplug both the mop and empty the water tank for your safety.
O que você precisa
Unwrap the power cord from the handle.
Remove the 56.0 mm Phillips head #2 screw located above the water tank cap.
Pull the handle to separate it from the body.
Remove the two 12.0 mm Phillips head #2 screws. Disconnect the control board.
