Ir para o conteúdo principal
Shark Pet Perfect II Front Belt Replacement
O que você precisa
  1. Shark Pet Perfect II Front Belt Replacement, Front Belt: passo 1, imagem 1 %32
    • Remove the motorized brush from the dust cup by pulling it apart.
  2. Shark Pet Perfect II Front Belt Replacement: passo 2, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the five 14mm screws from the face of the motorized brush.
  3. Shark Pet Perfect II Front Belt Replacement: passo 3, imagem 1 %32 Shark Pet Perfect II Front Belt Replacement: passo 3, imagem 2 %32
    • Separate the motorized brush face plate by using a flat prying tool.
  4. Shark Pet Perfect II Front Belt Replacement: passo 4, imagem 1 %32 Shark Pet Perfect II Front Belt Replacement: passo 4, imagem 2 %32 Shark Pet Perfect II Front Belt Replacement: passo 4, imagem 3 %32
    • Remove the brush roller by lifting vertically away from the brush head. It should come out easily along with the belt.
    • Be careful in handling the belt. If stretched or damaged, the belt can cause the motorized brush to operate incorrectly.
Conclusão
Documentos anexados
Tanner Brown
Membro desde: 06/27/17
459 Reputação
Autoria de 3 guias
Equipe
UW Tacoma, Team S1-G5, Liner Summer 2017 Membro de UW Tacoma, Team S1-G5, Liner Summer 2017
UWT-LINER-SU17S1G5
Membros da 4
Autoria de 8 guias
Um comentário
Thank you for this! I needed the picture to put it back together after I cleaned it out because it was not spinning. Working perfectly now! I also have an extra new battery if anyone needs it. :)
Aaron Woods - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 782
