Ir para o conteúdo principal
Shark Navigator Roller Brush Replacement
O que você precisa
  1. Shark Navigator Roller Brush Replacement, Roller Brush Compartment: passo 1, imagem 1 %32
    • Pop out the two small wheels located on the front end of the bottom of the roller brush compartment.
  2. Shark Navigator Roller Brush Replacement: passo 2, imagem 1 %32 Shark Navigator Roller Brush Replacement: passo 2, imagem 2 %32
    • Remove the 10 Phillips screws located on the bottom of the roller brush compartment. (Two of these screws are located under the wheels from the previous step.)
    • The screws have varying lengths, so keep track of where each one goes for reassembly.
  3. Shark Navigator Roller Brush Replacement: passo 3, imagem 1 %32
    • Remove the white plastic cover to expose the roller compartment underneath.
  4. Shark Navigator Roller Brush Replacement, Roller Brush: passo 4, imagem 1 %32
    • Lift the roller brush out of its holders.
Conclusão
42 outras pessoas executaram este guia.
Jeremiah Shyne
Membro desde: 03/27/15
1.403 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 5-4, Kish Spring 2015 Membro de UMass Dartmouth, Team 5-4, Kish Spring 2015
UMASSD-KISH-S15S5G4
Membros da 4
Autoria de 16 guias
35 comentários
Instructions where so easy to follow & right on the money. It took me 11 min from start to finish. PERFECT!!!
Cole bohn - Responder
Very helpful and easy. Thank you.
Kristi cox - Responder
Thank you. The owner's manual doesn't take into account needing to disassemble to clean the brush, for those of us with super long hair. Your instructions pointed out the screws under the wheels that we were missing.
birdofpyre - Responder
Ive uscrewed everything and this white piece seems to be stuck toward the rear. I even took the back whells off.
falynkinsey - Responder
Thank you so much. After having had to send in vac due to recall could not bare to part with it again to fix the belt. Your instructions for very clear and easy to follow. Thank you June
interhome1 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 15
Últimos 7 dias: 78
Últimos 30 dias: 326
Duração total: 99,764
