Ir para o conteúdo principal
Shark Navigator Lightweight Upright Motor Replacement
O que você precisa
  1. Shark Navigator Lightweight Upright Motor Replacement, Head Shell: passo 1, imagem 1 %32 Shark Navigator Lightweight Upright Motor Replacement, Head Shell: passo 1, imagem 2 %32
    • Detach the hose connected on the bottom of the vacuum by pulling it out of the casing.
  2. Shark Navigator Lightweight Upright Motor Replacement: passo 2, imagem 1 %32 Shark Navigator Lightweight Upright Motor Replacement: passo 2, imagem 2 %32
    • Lay the vacuum on its side.
    • Press in the black, rubberish button located on the back of the vacuum to detach the vacuum head from the body.
  3. Shark Navigator Lightweight Upright Motor Replacement: passo 3, imagem 1 %32
    • Flip over the vacuum head so the brush head is facing up.
  4. Shark Navigator Lightweight Upright Motor Replacement: passo 4, imagem 1 %32 Shark Navigator Lightweight Upright Motor Replacement: passo 4, imagem 2 %32 Shark Navigator Lightweight Upright Motor Replacement: passo 4, imagem 3 %32
    • Remove the small front wheels with a metal spudger by inserting the metal spudger in front of the wheel and slowly prying up. This will free the wheel and reveal the screw beneath it.
    • Repeat this for the other wheel.
  5. Shark Navigator Lightweight Upright Motor Replacement: passo 5, imagem 1 %32 Shark Navigator Lightweight Upright Motor Replacement: passo 5, imagem 2 %32
    • Remove the two 18mm screws with a JIS 1 screwdriver.
  6. Shark Navigator Lightweight Upright Motor Replacement: passo 6, imagem 1 %32 Shark Navigator Lightweight Upright Motor Replacement: passo 6, imagem 2 %32
    • Remove the four 18mm screws located on the top corners and the bottom/middle of the vacuum head using a JIS 1 screwdriver.
  7. Shark Navigator Lightweight Upright Motor Replacement: passo 7, imagem 1 %32 Shark Navigator Lightweight Upright Motor Replacement: passo 7, imagem 2 %32
    • Remove the two 18mm screws located on the inside of the large wheels using a JIS 1 screwdriver.
  8. Shark Navigator Lightweight Upright Motor Replacement: passo 8, imagem 1 %32 Shark Navigator Lightweight Upright Motor Replacement: passo 8, imagem 2 %32 Shark Navigator Lightweight Upright Motor Replacement: passo 8, imagem 3 %32
    • Remove the plastic cover by prying the plastic cover up using a plastic opening tool.
    • Prying in multiple locations may be necessary to create separation.
  9. Shark Navigator Lightweight Upright Motor Replacement, Motor: passo 9, imagem 1 %32
    • Locate the motor on the top right corner of the vacuum head shell.
  10. Shark Navigator Lightweight Upright Motor Replacement: passo 10, imagem 1 %32 Shark Navigator Lightweight Upright Motor Replacement: passo 10, imagem 2 %32 Shark Navigator Lightweight Upright Motor Replacement: passo 10, imagem 3 %32
    • Remove the belt from the motor gear by sliding the belt to the right.
  11. Shark Navigator Lightweight Upright Motor Replacement: passo 11, imagem 1 %32 Shark Navigator Lightweight Upright Motor Replacement: passo 11, imagem 2 %32 Shark Navigator Lightweight Upright Motor Replacement: passo 11, imagem 3 %32
    • Remove the white metal wire connector from the motor.
    • The white cable is positive.
  12. Shark Navigator Lightweight Upright Motor Replacement: passo 12, imagem 1 %32 Shark Navigator Lightweight Upright Motor Replacement: passo 12, imagem 2 %32
    • Remove the black metal wire connector from the motor.
    • The black cable is negative.
Conclusão
4 outras pessoas executaram este guia.
Suzie
Membro desde: 10/02/17
527 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S4-G6, Livingston Fall 2017 Membro de Cal Poly, Team S4-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G6
Membros da 3
Autoria de 12 guias
2 comentários
Where does one buy the replacement motor?
Michael De La Rosa - Responder
Where can I get spares??
ck
Clive Kingscote - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 45
Duração total: 9,507
