Ir para o conteúdo principal
Shark Navigator Lightweight Upright Hose Replacement
  1. Shark Navigator Lightweight Upright Hose Replacement, Hose: passo 1, imagem 1 %32 Shark Navigator Lightweight Upright Hose Replacement, Hose: passo 1, imagem 2 %32 Shark Navigator Lightweight Upright Hose Replacement, Hose: passo 1, imagem 3 %32
    • Locate the upper connection of the hose found directly below the base of the handle. Push in the the tab on the outside of the tube with your thumb.
    • Pull down on the tube while maintaining pressure on the tab.
    • Separate the upper connection of the tube from the housing, releasing the hose.
  2. Shark Navigator Lightweight Upright Hose Replacement: passo 2, imagem 1 %32 Shark Navigator Lightweight Upright Hose Replacement: passo 2, imagem 2 %32
    • Locate the lower attachment of the hose found in the bottom left corner.
    • Pull the hose down towards the floor, releasing the hose from the hose guide.
  3. Shark Navigator Lightweight Upright Hose Replacement: passo 3, imagem 1 %32 Shark Navigator Lightweight Upright Hose Replacement: passo 3, imagem 2 %32 Shark Navigator Lightweight Upright Hose Replacement: passo 3, imagem 3 %32
    • Pull up on the hose pipe located on the right side of the vacuum firmly.
    • Lift the hose pipe upwards and all the way through the plastic guide ring.
Conclusão
Uma outra pessoa concluiu este guia.
Kahye Yu
Membro desde: 10/02/17
446 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S4-G6, Livingston Fall 2017 Membro de Cal Poly, Team S4-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G6
Membros da 3
Autoria de 12 guias
3 comentários
Where can I find a replacement hose?
Vance Payne - Responder
How to replace the bottom pick up hose.
rgg20319 - Responder
How to fix the bottom hose?
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 17
Últimos 30 dias: 70
Duração total: 3,308
