Ir para o conteúdo principal
Shark Navigator Lightweight Upright Dust Cup Replacement
  1. Shark Navigator Lightweight Upright Dust Cup Replacement, Dust Cup: passo 1, imagem 1 %32 Shark Navigator Lightweight Upright Dust Cup Replacement, Dust Cup: passo 1, imagem 2 %32
    • Press down on the black, rubber ballish button located on the top of the vacuum.
    • Pull back simultaneous on the plastic handle and remove the dust container.
  2. Shark Navigator Lightweight Upright Dust Cup Replacement: passo 2, imagem 1 %32 Shark Navigator Lightweight Upright Dust Cup Replacement: passo 2, imagem 2 %32 Shark Navigator Lightweight Upright Dust Cup Replacement: passo 2, imagem 3 %32
    • Press the plastic tab in, located on the front of the dust container.
    • Pull up simultaneously on the plastic handle.
  3. Shark Navigator Lightweight Upright Dust Cup Replacement: passo 3, imagem 1 %32 Shark Navigator Lightweight Upright Dust Cup Replacement: passo 3, imagem 2 %32
    • Remove the dust cup from the inside of the dust container.
  4. Shark Navigator Lightweight Upright Dust Cup Replacement: passo 4, imagem 1 %32 Shark Navigator Lightweight Upright Dust Cup Replacement: passo 4, imagem 2 %32 Shark Navigator Lightweight Upright Dust Cup Replacement: passo 4, imagem 3 %32
    • Push in the red tab located on the side of the dust cup.
    • Open the dust cup simultaneously with the cone-half pointing downwards.
    • Separate the two halves.
Conclusão
Kahye Yu
Membro desde: 10/02/17
446 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S4-G6, Livingston Fall 2017 Membro de Cal Poly, Team S4-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G6
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 87
Duração total: 3,271
