Introdução
Use this guide to replace your vacuum belt. A vacuum belt may need to be replaced due to wear and tear, damage, or loss of tension.
The purpose of a vacuum belt is to transfer power from the motor to the brush roll. This allows the brush roll to spin and agitate the carpet or floor, loosening dirt and debris so that the vacuum can effectively suction it up.
Make sure the vacuum is not connected to power before proceeding.
O que você precisa
Use any object with an edge to twist the three locks counterclockwise to the "unlocked" position.
