Ir para o conteúdo principal
Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement
O que você precisa
  1. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement, Roller Brush Belt: passo 1, imagem 1 %32 Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement, Roller Brush Belt: passo 1, imagem 2 %32
    • Lay the vacuum down by hand and locate the roller brush underneath the vacuum cleaner.
  2. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement: passo 2, imagem 1 %32 Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement: passo 2, imagem 2 %32 Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement: passo 2, imagem 3 %32
    • Insert the metal spudger between the inside side of the wheel and the plastic body.
    • Push the metal spudger away from you to pop the wheels out.
    • Repeat the step to remove the other wheel on the other side.
  3. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement: passo 3, imagem 1 %32
    • Remove the six 15mm screws using the PH1 screwdriver.
  4. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement: passo 4, imagem 1 %32 Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement: passo 4, imagem 2 %32
    • Move the blue fulcrum connecting the bottom and the main body of the vacuum cleaner back and forth to loosen up crevice between the two halves of the roller brush enclosure.
  5. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement: passo 5, imagem 1 %32 Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement: passo 5, imagem 2 %32 Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement: passo 5, imagem 3 %32
    • Insert the plastic opening tool into the crevice between the blue and the dark grey plastic frames enclosing the roller brush.
    • Apply an outward force throughout and all around the gap in order to separate the two plastic frames.
  6. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement: passo 6, imagem 1 %32 Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement: passo 6, imagem 2 %32
    • Lift the grey frame off the bottom of the vacuum cleaner with your hands and place it on a flat surface.
  7. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement: passo 7, imagem 1 %32 Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement: passo 7, imagem 2 %32 Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement: passo 7, imagem 3 %32
    • Lift the roller brush slightly upwards using your hand.
    • Take one side of the black roller brush belt off by pulling it over the end of the roller brush with your other hand.
  8. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement: passo 8, imagem 1 %32
    • Remove the roller brush belt with your hands by sliding it of the end of the motor.
  9. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement, Roller Brush: passo 9, imagem 1 %32 Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement, Roller Brush: passo 9, imagem 2 %32
    • Remove the roller brush from the plastic frame using your hands by lifting it away.
  10. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement, Roller Brush Motor: passo 10, imagem 1 %32 Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement, Roller Brush Motor: passo 10, imagem 2 %32
    • Lift the roller brush motor up and away from its half-cylindrical holder with your hand.
  11. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement: passo 11, imagem 1 %32 Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement: passo 11, imagem 2 %32 Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement: passo 11, imagem 3 %32
    • Locate the two connectors coming out of the roller brush motor.
    • Pinch and pull the blue plastic insulation down the wire and away from the motor until the metal connectors are fully exposed.
  12. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement: passo 12, imagem 1 %32 Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement: passo 12, imagem 2 %32 Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement: passo 12, imagem 3 %32
    • Locate the protrusion near the connection between the metal and wire.
    • Push down on the protrusion with your finger and push the metal connector away from the motor with the metal spudger.
  13. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement: passo 13, imagem 1 %32 Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement: passo 13, imagem 2 %32 Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement: passo 13, imagem 3 %32
    • Continue to push on the connector away from the motor with the metal spudger until it is disconnected completely.
    • Repeat the steps 12-14 for the other wire.
  14. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Motor Replacement: passo 14, imagem 1 %32
    • Take the motor out and away from the motorized floor brush compartment by hand.
Conclusão
4 outras pessoas executaram este guia.
Equipe
Cal Poly, Team S15-G2, Livingston Fall 2017 Membro de Cal Poly, Team S15-G2, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G2
Membros da 3
Autoria de 14 guias
4 comentários
Well this looks really handy to read! Where can I get a replacement motor? Any helpful links!? :)
Matt Trainum - Responder
Yes! Where do I buy the motor?
bradschulz - Responder
Where do you find the motor? Any part numbers??
mantylajeremy - Responder
Where to find a motor? Shark has work to do!!!
Andre du Plessis - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 13
Últimos 7 dias: 61
Últimos 30 dias: 286
Duração total: 32,225
