Introdução
Replacing the roller brush motor can help improve the functionality of the vacuum cleaner. The roller brush belt needs to be removed first in order to replace the motor.
O que você precisa
Lay the vacuum down by hand and locate the roller brush underneath the vacuum cleaner.
Remove the roller brush from the plastic frame using your hands by lifting it away.
Lift the roller brush motor up and away from its half-cylindrical holder with your hand.
4 outras pessoas executaram este guia.
4 comentários
Well this looks really handy to read! Where can I get a replacement motor? Any helpful links!? :)
Yes! Where do I buy the motor?
Where do you find the motor? Any part numbers??
Where to find a motor? Shark has work to do!!!
