Ir para o conteúdo principal
Shark Navigator Lift-Away Deluxe NV360 HEPA Filter Replacement
  1. Shark Navigator Lift-Away Deluxe NV360 HEPA Filter Replacement, HEPA Filter: passo 1, imagem 1 %32 Shark Navigator Lift-Away Deluxe NV360 HEPA Filter Replacement, HEPA Filter: passo 1, imagem 2 %32 Shark Navigator Lift-Away Deluxe NV360 HEPA Filter Replacement, HEPA Filter: passo 1, imagem 3 %32
    • Press the latch below the HEPA filter on the bottom of the front body of the vacuum and pull outwards with your hands.
    • Pull the grey and blue plastic cover down and away with your hands.
  2. Shark Navigator Lift-Away Deluxe NV360 HEPA Filter Replacement: passo 2, imagem 1 %32 Shark Navigator Lift-Away Deluxe NV360 HEPA Filter Replacement: passo 2, imagem 2 %32 Shark Navigator Lift-Away Deluxe NV360 HEPA Filter Replacement: passo 2, imagem 3 %32
    • Pull the HEPA filter out by the grey plastic tab in the middle of the grate with your hands.
    • Wiggle it around as you are pulling if the HEPA filter is not coming out easily.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team S15-G2, Livingston Fall 2017 Membro de Cal Poly, Team S15-G2, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G2
Membros da 3
Autoria de 14 guias
Um comentário
I bought two different HEPA filters for the front, and they just blow off. What is the part with the tab that you push down to get the filter out? Is that an extra part cuz I don't even have that.
Kelly Kusemamuriwo - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 96
Duração total: 6,295
