Ir para o conteúdo principal
Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement
  1. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement, Foam and Felt Filters: passo 1, imagem 1 %32
    • Locate the latches on the side of the dust cup, the clear plastic chamber in the center of the vacuum.
  2. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: passo 2, imagem 1 %32 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: passo 2, imagem 2 %32 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: passo 2, imagem 3 %32
    • Pull the bottom of the latch with your hand in an upward direction.
    • Lift the top of the latch up and away from the dust cup using your hand.
    • Repeat the above steps with the latch on the other side of the dust cup.
  3. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: passo 3, imagem 1 %32 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: passo 3, imagem 2 %32
    • Lift the dust cup up and away by its handle on the top with your hands.
  4. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: passo 4, imagem 1 %32 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: passo 4, imagem 2 %32 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: passo 4, imagem 3 %32
    • Lift the foam filter up, out, and away with your hands.
  5. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: passo 5, imagem 1 %32 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: passo 5, imagem 2 %32 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: passo 5, imagem 3 %32
    • Lift the felt filter up, out, and away with your hands by the tab on the top.
Conclusão
Pramika Kumar
Membro desde: 09/30/17
258 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S15-G2, Livingston Fall 2017 Membro de Cal Poly, Team S15-G2, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G2
Membros da 3
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 14
Últimos 30 dias: 50
Duração total: 4,950
