Ir para o conteúdo principal
Shark Navigator HEPA Filter Replacement
  1. Shark Navigator HEPA Filter Replacement, HEPA Filter: passo 1, imagem 1 %32
    • On the front of the vacuum, locate the latch on the bottom of the front vent.
  2. Shark Navigator HEPA Filter Replacement: passo 2, imagem 1 %32
    • Press up on the latch and remove the front vent
  3. Shark Navigator HEPA Filter Replacement: passo 3, imagem 1 %32
    • Lift the HEPA filter out of the vacuum
Conclusão
3 outras pessoas executaram este guia.
Heather Shanks
Membro desde: 03/25/15
259 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 5-4, Kish Spring 2015 Membro de UMass Dartmouth, Team 5-4, Kish Spring 2015
UMASSD-KISH-S15S5G4
Membros da 4
Autoria de 16 guias
2 comentários
the taking out worked great but putting the new one back in is impossible.......will not fit i will not buy a new vac because of this........
lillian kresge - Responder
this is the second filter that i have purchased and it is the same...does not fit properly i could use a hammer to it?????
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 45
Duração total: 12,135
