Ir para o conteúdo principal
Shark Navigator Freestyle SV1106 Battery Pack Replacement
O que você precisa
  1. Shark Navigator Freestyle SV1106 Battery Pack Replacement, Battery Pack: passo 1, imagem 1 %32
    • Turn the device over to reveal the bottom of the motorized brush head.
  2. Shark Navigator Freestyle SV1106 Battery Pack Replacement: passo 2, imagem 1 %32 Shark Navigator Freestyle SV1106 Battery Pack Replacement: passo 2, imagem 2 %32
    • Slide the latch next to the panel upwards into the unlocked position.
  3. Shark Navigator Freestyle SV1106 Battery Pack Replacement: passo 3, imagem 1 %32
    • Slide the panel to the right to reveal the battery.
  4. Shark Navigator Freestyle SV1106 Battery Pack Replacement: passo 4, imagem 1 %32 Shark Navigator Freestyle SV1106 Battery Pack Replacement: passo 4, imagem 2 %32
    • Pull the battery from the vacuum.
  5. Shark Navigator Freestyle SV1106 Battery Pack Replacement: passo 5, imagem 1 %32 Shark Navigator Freestyle SV1106 Battery Pack Replacement: passo 5, imagem 2 %32
    • Disconnect the battery from the vacuum by pinching the white latch and pulling the two pieces apart.
Conclusão
3 outras pessoas executaram este guia.
Zachary Liu
Membro desde: 01/24/18
604 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S1-G5, Livingston Winter 2018 Membro de Cal Poly, Team S1-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G5
Membros da 3
Autoria de 10 guias
8 comentários
How much is the part for the shark
sumi49 - Responder
My Shark SV1106 doesn’t stay on very long. One episode you turn it on it immediately turns off. So what is the issue?
jklab23 - Responder
How much is a battery pack?
ridgeite145 - Responder
Items OrderedPrice1 of: 10.8V 3000mah Battery for Shark XBT1106N SV1110 SV1106N SV1110N SV11O6N SV116N Freestyle Navigator Cordless Stick Vacuum
Sold by: Areotek Direct (seller profile)
Condition: New
James Mayoral -
How much is a new battery pack for replacement
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 60
Duração total: 10,721
